    Mar 2010
    Thumbs down furniture refinish and repair
    I am refinishing an old china closet that had several coats of ugly paint on it. The closet is curved almost equal to a half circle. There is curved glass in the door as well as both sides. Three of the top and bottom mouldings that hold the glass in place (there are 6 total) are damaged. How do I find out what the radius of the glass is so I can cut new mouldings out of a solid piece of wood? HELP!!!
    Default Re: furniture refinish and repair
    There are several ways, the easiest will probably be to cut yourself a cardboard template of the inside curve. When you've got that fitting the way you like, transfer it to your wood.
