    Mar 2010
    Default need help with breaker
    what is the right way to test a 15 amp breaker?
    The deep South
    459
    Default Re: need help with breaker
    The right way is with a piece of test eqpt capable of maintaining a constant current output . Then you would need to know the manufacturers time curve . 15 amp breakers are cheap . If you have any doubts , replace it .
    wisconsin
    159
    replace it, or get an amp meter and check what the load is thats tripping it.
