    Mar 2010
    Question Moen Fixture Replacement.
    I have a garden tub with Moen fixtures.
    I would like to replace it, but is drywall and tile on the face of the tub.
    Can you advice how can I replace these faucets without removing the wall.
    Thank you.
    Default Re: Moen Fixture Replacement.
    You can do it if you've got access to the back of the wall, otherwise you're going to have to pull at least the wet wall tile to change out the valve.
