    Sep 2008
    Wink 3 way switch diagram
    I'm looking to wire a new 3 way switch. Two switch boxes and One light. I need a diagram on how to run the wire. The light will be in the middle of the room and a switch at each door.
    5,792
    Default Re: 3 way switch diagram
    For a basic understanding you might start here http://www.howstuffworks.com/three-way.htm/printable
    However a wiring diagram is going to depend on a couple of factors. 1] Is the source power going to the ceiling box or to one of the switch boxes? 2] is the wire from one switch box going directly to the other switch box or are all the connections going through the ceiling box?
    Sep 2008
    Jack thanks for getting back at me. I can wire it anyway as I have not started it yet. I thought I would run 14/3wg from box to box and bring power into the light. But I can do it anyway.
    Thanks
    Dick
    5,792
    This would require the least amount of cable for what you describe. Note I did not include the necessary ground wires in the drawing.
    Lakeland ,MN
    356
    Good drawing Jack but I would like to add as you have drawn it make sure you put the black wire on the terminal of the switch labled common.
    Harry
    5,792
    Good point Harry. I sometimes forget that sometimes people asking questions or checking answers may not have the necessary experience toalready know the basics. I made the change to mark rthe common.
