    Default Root Cellar floor
    I have a root cellar which looks similar to the one in this link.
    http://www.anr.state.vt.us/DEC/geo/i...t%20cellar.JPG
    The floor is simply the dirt ground. I want to use the cellar to store various items/equipment and therefore want to put in a floor. I thought of putting in a cement floor, but was told that that would not be a one man job due to having to mix and lay down the cement all in one day. Is this true or is it possible to lay a cement floor by working in sections over time? Are there alternative materials I could use that would work aesthetically well with this type of structure? Thanks.
    MN
    455
    Default Re: Root Cellar floor
    My understanding is concrete should be done in one pour creating a monolythic slab. If you stop and start the different sections won't be bound together and not be as strong. If you do this several times you end up with a similar thing as using concrete patio blocks which might be an alternative.
