    Sep 2008
    Default Blowing Cellulose into Wall with Some Insulation
    In blowing cellulose insulation into exterior walls that have some thin (1/4 in) insulation with a kraft backing already, where should the new insulation be blown? Between the insulation and the sheathing? Between the Kraft backing and the plaster? Both?
    I would like to keep the vapor barrier on the inside of all insulation, but this is leaving a lot of unfilled space in the wall since the existing insulation is nailed to the sides of the studs and lies right up against the sheathing. The backing won't expand enough to fill the whole space.
    Sep 2008
    Default Re: Blowing Cellulose into Wall with Some Insulation
    My understanding now is that the kraft backing doesn't form a very good vapor barrier at all, so it is probably okay to put the insulation on both sides.
    However, will try to drill 2 holes first and then push back the existing insulation thru the holes and then blow in thru the 2 holes.
    Oct 2008
    michigan
    32
    you may want to think about injection foam. that way you won't have to redo it in year
    injectionfoam.com
