    Mar 2010
    Albuquerque, NM
    Default leakey shower door
    I have caulked the inside and outside of the shower door and frame.The shower base is a fiberglass unit.
    The weep holes are clear on the bottom of the frame. I have also replaced the vinyl sweep. The water seems to be coming from one end on the bottom of the door frame. Any help would be appreciated.
    Aug 2009
    Rochester NY
    45
    Default Re: leakey shower door
    Can you take a few pictures and post them?
    Mar 2010
    Sometimes its not the bottom that is the problem. Take a look at the sides of the shower door when it is closed. if the door appears to be crooked the mist from the shower will run down the sides of the door to the floor. if the door is out of wack plumb it up and test it.
