    Mar 2010
    Default can lights with drop ceiling
    can i install can lights with a new drop ceiling?
    Shamokin, Pa.
    645
    Default Re: can lights with drop ceiling
    Quote Originally Posted by gomez41007 View Post
    I am assuming that you are talking about, say an Armstrong suspended ceiling system, correct? If that is the case, most can lights are manufactured with a bracket system as part of the unit that will work well for you.
    Mar 2010
    thanks i have since found this to be true
    Shamokin, Pa.
    645
    And the brackets do work well.
    You might be working in an area with limited space so the work may take time to finish. Not like one of those new_fangled TV shows where the project wraps up in twenty two minutes
    Good luck with the project.....
    Dec 2009
    Alpharetta, Ga
    55
    A couple tricks. You want to install the tile first and then the cans lights (but only the tile that the can light goes in). Also, get an empty trash can and a hole saw (the same size as your cans) and cut all the tiles you need at the same time over the trash can. It gives you a solid place to set the tile and catches the dust.
    Mar 2010
    ohmy, thanks for your help but i'm not quite sure i understand what you mean
