Results 1 to 10 of 14
Thread: Roofing
    Dec 2008
    meadville, Pa
    19
    Default Roofing
    Good or Bad. New roof over old roof?
    1,387
    Default Re: Roofing
    Howdy it depends on what type of roofing and code s in you area. If you have one layer of comp shingles and code allows a second layer and the currant material is laying flat with at least a 3/12 pitch. Not leaking. Then overlaying the roof is an acceptable repair. If the damaged to the roof is covered by insurance then tear off and install new felt and new shingles is better.... one claims adjusters opinion.
    6,480
    Default Re: Roofing
    Depends ...
    What the old roof and what are you putting over it? Most jurisdictions will allow two layers, again, depending on the type.
    You will get the best look and longest wear out of a single layer roof. Stripping the old will allow you to address any hidden dryrot or other problems that may be present.
    5,557
    Default Re: Roofing
    As far as I'm concerned, roof-overs should not be allowed under any circumstances.JMHO
    Dec 2008
    meadville, Pa
    19
    Cool Re: Roofing
    Recap,
    Ok I had a new roof put on my very old house. It is a 8/12 pitch.
    The person that did it built rafters OVER the old roof.
    Now I am having problems with Ice (not like we all don't around here) But ALOT of it.
    I was just up there tearing off the old shingles off of the old roof. It is very warm up there and it I believe should be at the same Temp as aoutside which is around 40 it is like 60 (at lea felt like it) above the old roof.
    Should the old roof been removed?
    HELP!!!!!:
    1,387
    Default Re: Roofing
    Howdy so you have the roof re roofed is the old roof vented and does that venting then get vented out the new roof?
    Is the ice on the north slope? and is it between roofs or on top of the new roof t word the bottom of the slope?
    Mar 2010
    Canada
    86
    Default Re: Roofing
    Quote Originally Posted by eaglesrfree View Post
    Recap,
    HELP!!!!!:
    It's not clear as to why another roof was placed overtop of the old one. Timothy Miller raised a good point, is the old roof vented into the space between and is there venting in place in the new roof?
    Even so, it sounds as though there is considerable heat getting into the attic which needs to be addressed. If that's the case sounds as though air sealing and increased insulation done in the attic is also needed. Removing the old shingles won't help other than reducing the weight on the roof, which is a good thing.
    If I were to place another roof covering over the old I would have laid sheets of foam down on the old roof surface, after removing the old shingles first mind you.
    Dec 2008
    meadville, Pa
    19
    Default Re: Roofing
    Quote Originally Posted by Timothy Miller View Post
    There are some hole in the old roof but I do believe that the outside air is getting trapped between the old roof and my ceiling. It is not getting to the new roof.
    Yes , my ice is on the north side and on the new roof towards the bottom.
    Default Re: Roofing
    Not quite following this.
    There are holes ( vents ? ) in the old roof. Are the soffit vents open into the attic ?
    Are there soffit and roof vents in the new roof ?
    Dec 2008
    meadville, Pa
    19
    Default Re: Roofing
    There are soffit vents and a ridge vent and a vent in the gable end. All in the new roof.
    The old roof has a few areas where some boards have been removed.
ID:	3265   Click image for larger version.
