Results 1 to 9 of 9
    Mar 2010
    Default Utility Cart Plans
    I am a new member to this forum and have looked till I am about to go blind on the website.
    I was watching the March 4, 2010 show and saw a plywood utility cart built as a project. Does anyone know where I can find those plans on the website, or are they not available?
    Any help would be truly appreciated.
    7,195
    Default Re: Utility Cart Plans
    Plans for a cart like that should be easy to find all over the internet. It will likely be a while, if ever, before ATOH gets around to posting plans for it. A quick Google of "work cart plans" pulled up all kinds of free cart plans. Here's one with many different configurations, all plans are free to download.
    http://www.woodworkersworkshop.com/r...%20shop%20cart
    This is also an extremely basic project. If you can use a measuring tape and a saw, you can build it yourself, without plans. All you have to do is determine the size you want the cart to be and start building it.
    A tip on the casters. Instead of bolting them from the bottom up, as Tommy did, bolt them from the top down. By that I mean put the bolt head in the bottom of the cart, then nut the caster on from below. This will leave the floor of the cart completely smooth. Tommy did it from the bottom up, not as clean an install. When you buy your bolts, you'll need to measure the thickness of the plywood, the caster mounting plate, and the thickness of the nyloc nut so that you get the exact length of bolt without having a lot of extra hanging down to get in the way of the caster, or, use any length you want and cut off the excess once they're installed.
    Mar 2010
    Thanks for your help. All I need to do now is get started.
    7,195
    Your welcome. Report back with your progress.
    Nov 2010
    Unhappy Re: Utility Cart Plans
    Here is my problem. Why show it and say "see the website" if you are never going to do what you say. I will give them a little slack but program aired in March and this is November and still nothing.
    I have spent hours searching for one that is even close but to no avail. I like this one. So put it on the site.
    Probably what happened is when the other guy made a suggestion about doing the wheels another way made them mad.
    Jan 2011
    11
    Really very very thanks for this nice information
    an outstanding work done
    Feb 2011
    9
    I like Utility car parks with some extra space.
    Feb 2011
    I keep getting Error Code 5, 7, and 2 when I try to view one particular folder in my email. What can be causing it?
    At first it would prevent me from changing the view selection , to view only the unread messages. After Yahoo "Fixed" the problem it won't even let me open that folder at all. Now, every time I try to view the folder it won't let me back into Yahoo Mail until I log out of yahoo and completely restart my computer.
    Feb 2011
    I am thinking of decorating my powder room with a spin. I am not sure if this will look tacky, or might be able to wing it. My utility cart is wider than this one approx. 3ft x 1ft. And if there is a consensus, then I plan to decorate with candles, towels, magazines, orchid etc. But, can't decide, whether it's a good idea? I haven't painted the walls as yet.
