Results 1 to 7 of 7
    Mar 2010
    Default GFCI installation
    I am going to install a GFCI on several outlets in the (3) bathrooms and kitchen. Would it be better to install a circuit breakers in my panel that has a GFCI? That would cover all the outlets on those circuits.
    Is this a better alternative?
    Thank you
    5,942
    Default Re: GFCI installation
    I would say it is a matter of convenience. Do you want to have to run naked from a bathroom to the panel in the basement to reset?
    Hard to follow up Jack's post.
    But --- or is it butt --- generally GFCI breakers are considerably more expensive than GFCI receptacles.
    7,598
    If leeteam's panel is anything like mine, it faces the street. I'm thinking the neighbors might complain about a streaker in the neighborhood.
    GFI outlets are definitely cheaper than breakers and you can control how many outlets are protected by where in the circuit they are installed and how they're wired.
    Mar 2010
    12
    Personally i would use a GFCI receptacle rather than breaker. When it trips you can reset it more easily, it's about 1/3 to 1/2 the cost of a breaker, and it will protect all devices 'down stream' from it just as a breaker would.
    Mar 2010
    I prefer the GFCI outlet over the GFCI circuit breaker. It's easier to reset at the source rather than going to the circuit breaker to reset it. Also, depending on how it's gonna be wired, you might not want to have several outlets wired to the same GFCI.
    Mar 2010
    5
    When it says dedeated circuit that means that should be the only thing on the circuit and seeing it wants one rated at 15 amps the motor is probally drawing 12 amps at start up so i would run the extra cicuit the gfi is to protect you from electric shock in the tub if something where to fail in the pump system.
