I completely understand the use of bandwidth and the posting of images, however, in regards to the size/dimension restrictions imposed by TOH, it makes it quite hard to see/understand what the poster is trying to convey. Most of the time, pictures are worth a thousand words, but in the case of the current TOH restriction, the images lack sufficient size to be able to determine the poster's intention. Please, PLEASE, increase the size restriction to at least double, if not larger, as the current thumbnail to "enlarged" size is negligible. I can offer you this, a standard maximum email dimension is 600x400 pixels, a similar size for the purposes of this forum would be good to allow sufficient viewing of problem areas in question. From there if there is insufficient clarity, we can ask that the poster crop and/or notate the image to indicate the problem area.
Thank you for the consideration of this issue.
A. Spruce
