Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
  1. #51
    Shamokin, Pa.
    645
    Default Re: Convert 2 plug outlet to 3 plug outlet
    Quote Originally Posted by Ravens53 View Post
    Well Baltimore city had ammended the code and at one time required conduit in a unfinished basement. People used Romex as a close line
    Exactly.
    The main reason that say 12/2 must run though floor joists in a cellar, not under them...
  2. #52
    Quote Originally Posted by kentvw View Post
    Canuk will go into sleepy time soon......... We try and humor him................
    LOL .... but he never goes away ...
  3. #53
    And mine .... big sky .... dang high rises
    We're quite proud of our tree .... it's a tourist attraction
  4. #54
    Shamokin, Pa.
    645
    Thanks for the pic.
    Being a coal cracker, it is truly amazing.
  5. #55
    Sep 2008
    I bought a house that was built in 1883. It use to have the old wire that ran through porcelain. Which at one time was changed over to two wire system. I am putting in 3-prong pluggins because buying cheaters all the time is a bummer. In my breaker box the neutral and ground bus bar are combined into one bar. My electric boxes in the walls are not metal, they are plastic single gang boxes. Being my neutral and ground wires run into the same bus bar in the breaker box. Can I run a ground wire from the neutral wire to the ground on my electrical outlets/pluggins? My neutral wires and grounds are the samething.
  6. #56
    MN
    455
    I'm no electrician but I don't think your allowed to physically attach the bare ground wires to the neutral wires at the same points.
  7. #57
    Sep 2008
    I think you maybe right, That's why I asked. Even though my bus bar in the breaker box is both neutral and ground combined. I don't think you can wire like that in the electrical box plugins. I doubt that would be code. I'll install 3 prong plugins for now and wire it as a 2 prong. Down the road, Maybe I'll take the old plaster and lats off and run some 12-2 or 14-2 wire so I have a ground to my boxes. That way it should be code. Some of my wires in the walls are fat black old things. Probably a good idea to replace them. The common wire has a cloth sheathing around it. Could be a fire hazard. So I'll wait. And replace it. Thanks for the help.
