    Question Noise following pressure control valve installation
    I just had a new pressure control valve installed about two weeks ago. Now I am noticing a "singing" noise whenever the water is on, somewhat similar to blowing across the top of a bottle, only louder. What could be causing this and will it go away eventually?
    Jul 2009
    Northeast
    661
    Default Re: Noise following pressure control valve installation
    You may have to adjust the valve open a little bit, also check and make sure that the pipe got secured
    11
    You also may want to verify that it wasn't installed backwards. There is an arrow on the brass casing.
    Plumbers protect the health of the Nation
