    Jun 2008
    17
    Default Granite Counter advice
    I have an island in my kitchen that is only 4'wide by 3' deep. I am replacing my countertop with granite and would like to know if I can extend the width to 5' so I have more working space. Is there a standard for the overhang.
    Apr 2009
    158
    Default Re: Granite Counter advice
    foot overhang will not be a problem. That's pretty typical for a sitting area.
    980
    usually for 2 C.M. granite an overhang of 6-8 inches unsupported. on 3 C.M. it is 8-10 inches unsupported. but the truth is that it depends on they type of granite that you choose. granite with a lot of veins in it would be on the lower side and other granites like uba tuba, tan brown, tropic brown, verde marinachi these would go to the higer side. and probally could exceed it a little depending on the slab.
    612
    If your overhang exceeds the recommended distance, you could make a few corbels to add support. One on each end and maybe two spaced in the middle. I did this for my peninsula and was able to match the cabinet color close enough so that you can't tell the corbels didn't come with the cabinets.
