    Default resetting copper fitting
    Can you reset or rotate a copper fitting that has already been sweated?
    8,046
    Default Re: resetting copper fitting
    Yes.
    If it's a fresh, unused joint it won't be any problem to reheat rotate and add just a touch more solder. It would be easier to replace an old joint than mess with cleaning and the possibility of leaks.
    2,009
    I agree with above
