    36
    Default outside door won't stay open
    Hello,
    We have put up a new door to the outside (storm door is between it and outside). However, the door will not stay open! It wants to swing closed! Is there a way to make it stay open, so that we can enjoy the air through the screen in the storm door? My husband thinks that he heard about adjusting the hinges a little, and that will keep it open more. Is this right? Thank you!
    Default Re: outside door won't stay open
    Does this include a new door frame as well?
    Generally if the door wants to swing shut it usually means the frame is out of plumb.
    731
    or mabe a breeze stirred up with another opening and the wind sucks the door closed this happens easily when a door is perfectly installed level and plumb and the pressures get imbalanced inside to outside.
    the other thing is if a prehung did you replace some of the shipping short hinge screws with long enough screws to bite into the framing to not have stress spring the hinges.
    5,940
    If all elese fails, pull one of the hinge pins, lay it on a solid surface, and tap it in the center with a hammer to get a slight bend, reinstall. That will usually get enough of a bind to hold the door in what ever position you put it.
