Thread: Yamdot
    Sep 2008
    Default Yamdot
    My 66 yr old home has settled leaving me with a minor hump in the middle of my home. I have called 4 different foundation repair companies out. I received 4 different ideas. The one idea I never heard of before, probably because I never had this issue before. Since the foundation of the house have already settled and the main support that runs the full lenght of the house is about 1/2 " higher I should jack up the center of the house, cut the vertical support no more then 1/2" and lower the jacks. What I have a problem with is that no matter how hard I look I can't seem to find any information anywhere on the web about this procedure. Is this safe? How do I find someone who can do this type of Job?
    Default Re: Yamdot
    This is a common proceedure.
    Either screw or hydraulic jacks will be used to slightly raise the center beam .... just enough to take the weight off the existing support columns for removal or for shortening..... depending on what the existing support columns are made of.
    The jacks will be slowly lowered to bring the center down to reasonably level .... the shortened support columns will then be installed permanently.
    It might be new columns can be installed and may be adjustable columns called teleposts ... they may be steel 4 inch square tube with a large threaded rod or a round steel column with a similar threaded rod used for adjutment.
    It's not uncommon for foundation repair companies to do this or a general contractor.
    Hope this helps.
