Thread: plumbing noise
    Question plumbing noise
    when i run water any where in the house the water noise is loud,like too much water pressure,anyway to quiet noise level when water is running.
    163
    Default Re: plumbing noise
    Quote Originally Posted by frank scytkowski View Post
    Does this happen anytime you run water, or does it happen sometimes, but not others?
    More detail would be helpful.
    Jul 2009
    Northeast
    661
    It could be your water pressure, if the noise bothers you that much you can get a pressure testing gauge and test the pressure at your outside spigot, I believe it should be no more than 80 PSI. When you do the testing be sure it is done at times of the day when your neighbors aren't using the water that much. Like late at night or real early in the Morning
    Quote Originally Posted by rdesigns View Post
    water is loud all the time.
    Quote Originally Posted by Sten View Post
    is there a way to reduce water pressure in side of house. thanks
    South*East
    1,259
    If it is over 80# then install a pressure reducing valve. (PRV)
    John
    Jul 2009
    Northeast
    661
    Follow the link for more info, you would want the one that goes in after your water meter.
    http://www.watts.com/pro/divisions/w...about_wprv.asp
