Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: lvls loading
  1. #11
    5
    Default Re: lvls loading
    I suggest you click on Science & Mathematics in the category list, then click on Engineering and ask your question there. These guys and gals are pretty darn smart.
  2. #12
    1,387
    Howdy, Thank you Alton.cedric for your help. I will.
  3. #13
    Timothy, you really should be asking technical questions with the manufacturer --- they and only they can give the approved answer to fastening and loads.
  4. #14
    1,387
    Thanks i agree am wanting structural engineer input. However have learned some& hope it helps others too.
    http://www.ilevel.com/literature/TJ-9000.pdf
    Anyone do any lateral loading to assembled beams hanging joists that can share how they nailed the beams in addition to the nails to make the beam. If only one side is loaded then a strong need to add substantial fasteners between every joist and on both sides of the beam. If i am learning correctly up to 24 nails on each side. So am going to use GRK RSS screws between the joist hangers so i can install less fasteners with more strength. To me it's sure interesting to learn.
    http://www.grkfasteners.com/
  5. #15
    1,203
    For a substantial fastener on your unequally-loaded girder, maybe some joist hangers made from 1/4"x3" angle iron and bolted on/through. Takes the flex out.
    S_M
  6. #16
    1,387
    Quote Originally Posted by Sombreuil_mongrel View Post
    S_M
    Howdy great idea thanks again for sharing your knowledge. Tim
