    11
    Default Installing a Ceiling Fan
    I would like to install a ceiling fan in one of my rooms but have doubts if it's wired correctly for it. I'm replacing an old flush mounted light on a dimmer switch. House built in 1885, no idea when the electric was upgraded last. I dismantled the light. Coming out of the box was a white wire, A black one and the ground. Is this sufficient to wire a ceiling fan? In my attempt I could get the light on the fan to turn on/off but never the fan motor to operate. I ended up putting the old lamp back,
    612
    Default Re: Installing a Ceiling Fan
    Three things come immediately to mind. Others may think of something else.
    First is that most fans do not like dimmer switches. You should swap that out with a regular switch if you have not already done that.
    Second is that there were probably a blue and a black wire in the fan assembly. Both should be wire-nutted to the black wire in the ceiling box. All the whites should be wire-nutted together in the ceiling box.
    Thirdly, did you check to see if the existing box was rated for the weight of the fan? Fan boxes are more "heavy duty". I also always try to mount the box to a 2x4 that is between the ceiling rafters for additional support.
    Hope this helps.
    Baltimore, MD
    76
    Ditto on everything BP said... especially the parts about securing the mounting box and replacing the dimmer with a switch.
    If you still want the light to dim you can purchase a remote that controls a receiver that you mount in the canopy. This will also allow you to control the light and fan independantly without pulling a new wire.
