    Default point of use water heater
    In your vido series, you state that the heater should be connected to copper water lines. Question, If I have a Pex system can I connect the Pex tubing to the heater, or do I need to use copper tubing?
    Default Re: point of use water heater
    You will need to attach copper/brass fittings along with a shut off valve onto the heater itself --- the pex gets connected to those.
    11
    Pex can't be installed within 18 inches of the water heater according to the Uniform Plumbing Code
    Plumbers protect the health of the Nation
