Results 1 to 10 of 12
    Default Hot Water Heater
    Need to replace a 19 year old 50 gallon gas hot water heater. What are the pros and cons of going to the new tank less style or should I just install a new tank style unit. Our house has two and a half bathrooms and two people living here.
    Default Re: Hot Water Heater
    Tankless units have the advantage of taking up less room and can be energy savers. However, the common complaint is variations to the flow rate of hot water being produced. While they produce continious heated water many people are surprised when these units don't meet their expectation of large volumes of hot water.
    The temperature of the cold water supply and the demand are main factors as to how much heated water these units will produce and supply. The colder the supply water is --- the longer it takes it takes to heat --- the less volume being supplied.
    As demand increases this also limits the amount or temperature of the heated water the units can produce and supply.
    It's very important to properly size these units to worst case scenerios.
    Price of tankless units run at least 4 times the price of standing tank units.
    Just some thoughts.
    566
    I am in complete agreement with canuk's comments----in my opinion, well-stated and accurate.
    Coventry, RI
    340
    I've had a Renni tank-less water heater for about 3 years now and for the most part love it. It has provided plenty of hot water (dish washer and showering at the same time). You can get them with different flow rates depending on your needs. My one main complaint would be that they are fairly noisy while running. I put mine in a closet near the upstairs bathroom. Currently I live alone so its not a big deal but I suppose if someone was sleeping while someone was taking a shower it might be a little loud. If its going to be in a basement this shouldn't be an issue however. As was stated they are considerably more expensive than a regular tank style water heater. They are however expected to last 25+ years that's usually a minimum of 2 regular water heaters but most likely 3. Then there is the savings in fuel costs since you are not heating water that you aren't using while out or sleeping. If you're staying in your house for a long period of time I would consider a tank-less. If you are planning on moving in a few years its probably not worth the extra money.
    Mike
    6,114
    If you are talking about a gas unit, you may also have to install a significantly larger gas line.
    If you are talking about electric, as an alternative you might want to consider a high efficiency WH like the Marathon WH.
    Coventry, RI
    340
    Good point Jack, I didn't think to mention about the gas line. Tank-less water heaters that run on gas generally require a larger volume of gas while running than a tank style gas water heater. Mine is a propane model since there is no NG in my neighborhood.
    Mike
    I recently installed a Reni on demand water heater...It takes an extremely long time to get hot water to my faucets, even the ones closest to the heater..I have upgraded 70% of the piping to 3/4 inch. And have upgrade the propane line and tank to handle the new volume. Any helpful hints on how to get hot water to our faucets quicker so we do not have to waste so much water?
    Jul 2009
    Northeast
    661
    On Demand water heaters are known to be slow at providing hot water, here's something I got from the Net.
    A gallon of water will fill 63 feet of inch galvanized iron pipe, 36 feet of inch galvanized pipe, or 20 feet of 1 inch galvanized pipe. In the case of type K copper pipe, a gallon of water will fill 88 feet of inch pipe, and 44 feet of inch pipe.
    This means that if you run your faucet at 2 gallons per minute, and you have 1 inch galvanized pipe, the water will travel 41 feet per minute. However, if you have inch type K copper pipe, the water will travel 176 feet per minute, quite a difference. So the smaller the diameter of the pipe, the faster the hot water will reach the fixture, given the same flow rate.
    Also I don't know what you did as far as upgrading your Propane Line but there are things that should be considered, BTU's, Length, pipe size. All this is measured in water column or the amount of pressure it takes to move a certain amount of water an amount of inches. With Natural Gas you should have 7 inches of water column on the incoming side and 3 1/2 on the manifold side, this is adjustable at the gas valve, (NOT TO BE ADJUSTED BY ANYONE THAT HAS NOT BEEN PROPERLY TRAINED TO DO THIS).
    I believe the water column for Propane is 11 inches which could change if the pipe dia. has been altered but the sizing is done the same as NG but the nos. will differ. Any alterations that are done on NG or Propane should be done by a properly trained Tech
    Just my two cents, I hope if someone has more info they will add to the post
    Wouldn't they both take 1 minute to supply 2 gallons ?
    Jul 2009
    Northeast
    661
    If your faucet is rated at 2 gallons per minute it will always give you that amount, but there is more water in a 1 inch pipe than a 1/2 inch pipe so the velocity of the water in a 1/2 inch pipe will be greater to make up the diff. It's all depending on the GPM rating of the faucet or showerhead.
    In answer to your question yes, but the velocity is what makes up the diff.
