    6
    Default Bathroom Remodel-Uses for Knotty Pine
    I am planning to remodel basement bathroom which currently has knotty pine on two walls - is there any use for this material, is in very good condition and it's all over the basement making it dark. I am considering beadboard or wainscoting rather than tile for the wall to keep the cost low. A friend suggested knotty pine can be painted and used still - any ideas?
    Thanks
    Dec 2009
    Casper, Wyoming
    159
    Default Re: Bathroom Remodel-Uses for Knotty Pine
    I think you should paint it. I have seen it done and it looks great if you are careful and follow the basic steps:
    1)
    Wash
    2)
    Sand
    3) Nail down any loose seams and caulk to fill gaps.
    4) Prime it with 2 coats of shellac based primer.
    The shellac is what blocks the knots from bleeding through.
    Let it dry overnight and
    5) Paint with a good latex acrylic paint, 2 coats.
    Good luck!
    ____________
    Painting Networx - licensed, professional painters in your area.
