    Default Thick Wood Planks Screwed into Floor
    I just purchased my first home. The only downfall is that there is wood (wood the you would use to build a fence or a barn)screwed into the family room and kitchen floors. Most of the screws are stripped or painted over. Besides using a pry bar and some muscle, what would be the best way to tackle this project? Any help or ideas would be greatly appreciated. Hopefully I will have pictures to post soon.
    Thanks in advanced.
    Hudson Valley New York
    Default Re: Thick Wood Planks Screwed into Floor
    The easiest way is to cut the boards between each joist with a circular saw. Set the saw to the thickness of the board and run it right through. Then use a chisel or pry bar to split the wood around the screw. Once you get the board up, you can tap the screws sideways and they will snap off.
    Cyril Prendergast
    Kitchen, Bath & Home Remodeler
    Serving Dutchess County, New York
