Thread: wall insulation
    va
    Default wall insulation
    whats the best way to test for exterior wall insulation other than cutting holes heating bill 564.00 help please
    clio,mi.
    5
    Default Re: wall insulation
    In 2008 we had a company called Michigan IR do a energy audit on our house. On a cold day you turn up the heat inside your house and they use a infared camera on the outside, They showed use all of the heat lose we had around our windows and the heat lose because of poor insulation.
    5
    One thing many of my clients are concerned with is the sound of the water pipes from the bathroom. Any insulation helps to block sound transmission, but make sure you also take care of the pipes. They must be securely attached (rattling pipes are always heard) also have the pipe insulated with the neoprene insulators. then insulate the wall.
