    Default Radon Mitigation with ASD on outside wall of CBS slab 1-level house in south Fl.
    Radon Mitigation with ASD on outside wall of house.
    My CBS slab 1-level house in south Fl. has high radon levels.
    1. I called several professionals and was unable to get someone to install an ASD (Active Soil Decompression) system to reduce radon levels in south Florida.
    They all want to increase inside house pressure using the air-conditioning system instead.
    Should I install an ASD system on the outside wall of the house myself? Why can't I get a pro to install ASD in south Fl ?
    2. Should I x-ray the plumbing in order to locate the breach in the slab foundation so I can lift the bathtub or other plumbing fixture in order to polyurethane caulk any slab breaches to reduce radon ?
    3. Should I lift and reseal loose floor tiles to reduce radon ? Will it make any difference ?
    MN
    455
    Default Re: Radon Mitigation with ASD on outside wall of CBS slab 1-level house in south Fl.
    Have you had an indoor air quality test that indicates there is a high level of Radon gas?
    Most times you can simply seal all peneterations in the slab to help controlling the gas leakage into the home.
    Yes I had the test and the levels are close to 11.
    This is why I ask:
    Should I x-ray the plumbing to find the penetrations?
