    Default Glue-in toilet flange?
    Greetings all...this is my first post. Happy to have found the forums.
    Installing a toilet in a new construction (my place) and am wondering about typical flange install. I didn't put the flange in prior to the finish floor which is tile.
    In reading about general flange installation over the web, I rarely see any mention of how to secure the flange to the drain pipe below. Is this typically done with PVC glue as shown in the pic? I have seen articles talking about replacement of flanges, but none dealing with the burdensome task of dealing with a glued in flange.
    The way the flange will fit in my particular instance is with the flange pipe going into the drain. It is one that fits inside of a 3" pipe.
    Thanks!
    new castle, pa
    5
    Default Re: Glue-in toilet flange?
    yes the flange is glued in.
    whether it is done before or after the finish
    floor is installed depends on the type of floor
    on tile i like to install the flange first for
    2 reasons: first you have to screw the metal ring
    down and screwing into plywood is easier than drilling
    through the tile. second you run the risk of cracking
    the tile.
