Thread: sump pump
    Post sump pump
    I NEED TO KNOW CAN I PUT A SUMP PUMP OUTDOORS, THE REASON I ASK IS TO PUT A STOP TO MY NEIGHBORS WATER COMMING IN MY YARD, YOU SEE I LIVE IN THE COUNTRY AND WHEN THE HOUSE WAS BUILT THE WASH WATER WENT INTO THE POND, BUT THE NEIGHBOR PLUG THE DRAIN ON MY END HE IS NOT VERY NICE ABOUT THE INNCIEDENT SO I HAD A HOLE DUG VERY DEEP TO DRAIN THE WATER HIS POND LEAKED THRU, MY QUESTION IS CAN I BUY A SUMP PUMP TO GO OUTDOORS IN THIS 5FT. OF WATER TO DRAIN OUT THE HOLE HELP PLEASE CHARLENE
    1,387
    Default Re: sump pump
    Howdy depends on where you live .. if it freezes or not for starters.
    Quote Originally Posted by Timothy Miller View Post
    i live in north carolina it does freeze somtime but i need to get this water out of the hole quick get this it is 5 foot deep
    1,387
    Howdy again, ok so without any information about where the water comes from or how your lot slopes or the plugged drain. You can simply put in a submersible pump, sump pump, and pump the water out where too i can only guess.
