    Default Use of vapor barror in shower
    should you use a vapor barrer around shower or not, i live at 9300 ft with low humidity and everont says no including buildinginsp as this will cause mildew and mold. Any help will be helpful
    thanks bill
    Coventry, RI
    340
    Default Re: Use of vapor barrier in shower
    If the Building inspector says no you should not use it. You should however definitely have a good ventilation fan in the bath or even in the shower that exhausts to outside.
