Thread: Help
    Default Help
    We had our tri-level insulated with foam around 1980...have found it to have turned to powder...is there a way to remove and reinsulate with foam or another form of insulation without tearing the whole ourside off?
    Oct 2008
    michigan
    32
    Default Re: Help
    if all the old insulation turned to powder than in can be reinsulated with injection foam. do you rember the name of the old foam that was used???. if i were to bet it was a Urea formaldehyde based foam. was/is there an oder?
    justin
    abertke@frontiernet.net
    injectionfoam.com
