Thread: bathtub vent
    Default bathtub vent
    I am in a 3 year old house and all plumbing worked fine when I took possession. Recently (last 4 months or so) the master bath tub makes a gulping noise as if it's not properly vented when draining. We also notice that when the master bath shower is used (separate from tub) there is a banging noise coming from the drain. All the other baths and drains work fine. Is it possible to get a air lock in the drains? Anyone have any ideas of the cause and possible remedies? Thanks
    Default Re: bathtub vent
    The installer might have used Studor vents for your master bath. I've had all types of problems with them and if possible try to have a plumber run a vent from master bath group to outside.
