    Smile Shower insert for Shampoo bottles and soap
    WE are redoing a shower and are trying to find a shower insert that fits in the wall and holds shampoo bottles and has a small shelf under it for soap. Can anyone tell me where I can buy one?
    109
    Default Re: Shower insert for Shampoo bottles and soap
    Are you looking for a finished niche (fiberglass or solid surface material) or a form which you plan to tile? or a surface tiled-in mounted corner unit?
    Examples http://aquafit-usa.com/Merchant2/mer...ategory_Code=R
    http://www.johnbridge.com/vbulletin/...php/t-241.html
    http://raficreations.com/sc_pastas.h...FRILIgodf2Jhbg
    If you substitute niche for insert and search shower niche I think you'll find many options for whatever type you are looking for.
    7,592
    As Gray pointed out, it is indeed called a "niche". They are available premade for tile and cultured surrounds, or custom made on site to any dimension needed.
    Not sure about fiberglass units as an aftermarket feature because fiberglass units are generally mold the niche into the wall during manufacture.
    Thank you so much for all your help, I did find what I need
