    Default Cultured Marble Countertop troubles
    We have installed 3 new cultured marble countertops. Only one of the countertops has gone on without difficulty and fits tightly.
    Two of the sinks have gaps in the front between the vanity and countertop. We have taken the sinks off numerous times and cut out a spot for the drain, made sure the vanity was level, etc but still cannot figure out how to level the countertop. The vanity appears to be relatively level. Is there anything we haven't thought of???????
    6,114
    Default Re: Cultured Marble Countertop troubles
    Is it possible that the sink is hitting the from frame. Perhaps the vanity is to far back or the wall is bowed and pushing the top to far forward. Try sliding the vanity out a little and see if it then drops down into place.
