Results 1 to 10 of 28
    Question electric bill is killing me
    Long Island. electic bill is $385 a month and I heat with oil. They just added a sur charge ( they did not raise the rate. They just added a sur charge of $350.
    I have a new electric hot water heater. Is there a switch or a timer that could be put on so I am not heating water all night and all day when one one is home?
    The deep South
    459
    Default Re: electric bill is killing me
    Yes , water heater timers are available , but I wouldn't expect your savings to be life changing .
    You might consider an insulation blanket for the tank to start with ..... it will be a cheaper place to start.
    1,131
    It's time you moved elsewhere.
    Lakeland ,MN
    356
    Change your light bulbs to new compact florescent lamps. Turn lights off when not in use. Have a hot tub? swimming pool pump or heater. They can have timers too
    Harry
    Sand Springs, OK
    467
    I'd suggest a programmable thermostat and keeping it at 78 in the summer and 68 in the winter.
    My cooling program is 78 from 6 am to 5 pm, 75 until 10 then 72 over night because my husband has to be cool to sleep.
    When heat is needed the heating program is 68 during the day and 65 at night.
    Don't forget to put your electronics on power strips and turn the strips off when your done with them. Unplug all your appliances but your refrigerator if you can.
    Debby in Oklahoma
    Maryland
    1,911
    My bill was $378 last month too.
    Luckily the weather has been unseasonably cool the last couple weeks & I haven't had to run the A/C. That should make a big difference next bill.
    We're all in this together. And if not deregulation is liable to catch up to you eventually.
    The deep South
    459
    My last electric bill was $90 . NG was $50 .
    2000 sq. ft. South Louisiana heat and humidity . You'r power company is doing something really WRONG .
    1,131
    Yes...it's called a breaker. Just flip it off and flip it on.
    Quote Originally Posted by jem3 View Post
    I just installed a tankless water heater. The cost is about the same as a regular heater but the cost of operation is less than half. The best price is on ebay.
