    Sep 2008
    Default Ratcheting PVC Pipe Cutter
    On a recent show, Richard used what was a regular ratching PVC pipe cutter except that the "platform" that the pipe lies against and the blade passes through appear to be much wider than regular cutters. The idea, of course, is to get a straight cut. It didn't occur to me to save the episode because I didn't need the tool at the time. However, I sometimes make things out of PVC, and having a straight cut is critical. The BrassCraft T012 cutter that I have will NOT make a straight cut when cutting near the end of the pipe. The "wings" on the platform appear to extend an inch or so on each side of the blade.
    Default Re: Ratcheting PVC Pipe Cutter
    Not sure which one you mean but here's a couple to look at ----
    Miwaukee powered one http://www.homedepot.com/webapp/wcs/...5X-_-202042892
    hand operated ratchet types http://www.plumbingsupply.com/pvccutters.html
    Hopefully this helps.
    Sep 2008
    These are like the ones I have and look very similar to the ones that Richard used. However, the ones I'm searching for have bottom jaws have "wings" on them, for lack of a more accurate description, that stabilize the tubing and allow a clean, 90 cut.
    8
    Is it critical to use and actual pipe cutter? I often use my small mitre saw with a used fine blade to cut PVC. Seems to work really good for achieving straight clean cuts. Just a thought
    Jul 2009
    Northeast
    661
    Quote Originally Posted by bcsukas View Post
    Miter saw works awe some
    Mar 2010
    Thanks for your article my friend
    To be frank,Ratchet PVC Pipe Cutter is hard to operate
    And the cutting surface is not very well
    At present ,We use the Battery Powered Pipe Cutter
    The manufacture name is YueQing Vanfo Electric Co.,Ltd
    Website : www.vanfo.com
    If someone are intersted ,You can contact with them directly
