Results 1 to 8 of 8
    Madison, WI
    Default GFCI hard to plug into
    Our house was built in 2001. Since day one, several of our GFCI outlets have been tough to plug into. They function, they're just "sticky." Is this how they are supposed to work?
    Default Re: GFCI hard to plug into
    Different manufacturers will make the contacts snug while others don't ---- basically it's hit and miss as to how snug they are.
    Dec 2009
    Alpharetta, Ga
    55
    There is a tool that measures the proper tension on the outlets, I am not sure if its something that you can get at a HD or Lowes. Its called a tension test or something like that. Generally, GFI's are a little tighter which is a good thing. You want a strong connection.
    Quote Originally Posted by ohmy View Post
    Let's see --- by a device to check the tension --- and then what ?
    Unless it can make adjustments to the tension I don't see the point. Besides, the OP has pretty much tested it for free.
    5,836
    Hard to plug in usually means it has better and heavier contact springs.
    I work at Lowes part time in the electrical department. At my store we don't sell it but you may want to check your local store.
    Dec 2009
    Alpharetta, Ga
    55
    http://www.woodhead.com/data/current...struments2.pdf
    Here it is. Its called a woodhead Receptacle tension tester (generally its used for testing to see if outlets in a house are worn out, but I guess you could use it the other way).
    I don't own one.
    Still don't see the point of checking the tension level when you can't do any adjustment.
