    Sep 2009
    7
    Default bathroom exhaust fan vent
    i have installed a bathroom exhaust fan which will vent through a side outside wall.is there another way to connect the vent pipe to the outside other than a clothes dryer vent connector, the type with the three flaps,or is this the only way. i will be using 4" galvanized vent pipe....thanks
    Jul 2009
    Northeast
    661
    Default Re: bathroom exhaust fan vent
    They have venting kits just for this and you should be aware that you could get discoloration on your siding, the roof would be a better choice. Follow the links for more Info
    http://www.kitchensource.com/bathroom-fans/br-rvk1a.htm
    http://www.doityourself.com/stry/bathexhaustfan
    http://www.residential-landscape-lig...mp_heaters.htm
    I disagree with roof venting being the better option --- it lends itself to other issues -- besides if you get discoloration on the siding you will also get it on the roof.
    I'm not sure what the concern is with the exterior hood --- if it has to do with not using the louver type there are typical sloped hoods available. Whichever type you choose make sure it as a backdraft damper to prevent outside air getting into the ducting.
    Jul 2009
    Northeast
    661
    Yeah, your right
