    Camp Point, IL
    Default Replacing old door lock
    I have an old entry wood door. It has the old skeleton key lock, etc.. I have seen these keypad door locks. Is there any way to install one of these or is there a replacement to use instead of the old skeleton key parts??
    5,942
    Default Re: Replacing old door lock
    You can always add a keypad dead bolt above the lock, or replace the lock assembly with a new one. A new lock set may require you to make a block to fill the old mortised hole befor drilling and installing a new lock set.
