Results 11 to 20 of 22
Thread: House Dust
  1. #11
    Iowa, Quad-Cities area
    129
    Default Re: House Dust
    Quote Originally Posted by thommy View Post
    fresh air enters the house thru the return duct located on the furnace .it is filtered before entering the house.the fresh air exchanger also has it own filter.
    Right. Thank you. I'm at a loss as to how the dust is getting into your house. Is your hi- eff. filter getting dirty, quickly?
  2. #12
    Sep 2008
    24
    Quote Originally Posted by Bob Gabrilson View Post
    no.it's been in service 60 days and looks new.I keep a replacment handy for comparison.
  3. #13
    129
    If your filter is not getting dirty, then that's a sign that the (return) air is getting around the filter and the air is not being cleaned. Check to make sure that you have a bottom in your furnace.
  4. #14
    Sep 2008
    24
    there is a bottom in the furnace.the filter housing has a good seal.keep in mind what I said about the 3 rooms I dont use.if the furnace is pulling dust from the house,then dust should be accumulating in these rooms.there is no dust in these rooms.
    the furnace is fully functional in these rooms.
  5. #15
    MN
    455
    I am not sure what a heat vent is?
    That's surprising since you're pretty familar with the workings of the mechanicals. The heat vent is where the warm air comes out into the room.
  6. #16
    MN
    455
    Since you have the doors closed off to these rooms maybe it is your vacuum.
  7. #17
    Apr 2010
    10
    It worked for me thank you!
  8. #18
    The bedroom should be cleaned daily and given a thorough cleaning weekly. All cleaning in the house should be done with a vacuum, wet mop or wet dust cloth, never with a dry broom, dry dust cloth, or dry mop.Daily damp dust the plastic mattress cover.
  9. #19
    Sep 2008
    24
    I discovered the source of the dust.
  10. #20
    7,078
    Which was?
