Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: House Dust
    Sep 2008
    24
    Unhappy House Dust
    House dust is an issue most people deal with.for most homes,dust accumulates slowly,taking several weeks.
    But,what do you do when dust accumulates within one day
    of a complete cleaning?dust that can be seen,and collected.
    the problem house is a 1450sq ft ranch,with a full basement.
    it is 14 years old.I had the house built.I am the first,and
    only occupant.no pets.it has central heat,and a/c.the
    furnace is fueled by propane.the attic insulation is
    blown in.no duct work exists in the attic.the dust problem
    began within the first year.the furnace is equipped with a
    hi efficiency filter.I also have a fresh air exchanger.I
    sealed all the gaps in the furnace ducts.the cloths
    washer and dryer are located in the basement.
    there are 3 rooms I dont use.I keep the doors to
    these rooms closed.dust will not accumulate in these
    rooms as long as the doors are closed.the house is fully
    carpeted except for the kitchen.knowing the composition
    of the dust, might even lead it's source.
    7,160
    Default Re: House Dust
    I suspect that one or more of the ducts are split and drawing in dust/dirt from the surrounding area. Another problem may be the locations of the return air inlets, anything down at the floor is going to pick up more dust/dirt than an elevated inlet. Filters in a furnace are not tightly sealed, a significant amount of dust can be drawn around the filter, especially when the filter becomes partially plugged, therefore it is important to always keep your filters clean.
    Sep 2008
    24
    All of the duct work for the furnace is visible.if there is a
    split,I dont see it.I forgot to mention the return air ducts are high on the walls.the return air ducts are actually the spaces in between the studs.
    Thanks for your response.
    Iowa, Quad-Cities area
    129
    How does your "fresh air exchanger", or better known as a heat recovery ventilator, dump the fresh air into your home? That might be one source of your dust. I've seen where the heating system is pulling air from the attic (insulation dust) but your filter should be loading quickly if that were the case.
    MN
    455
    Quote Originally Posted by thommy View Post
    carpeted
    I'm not sure how anyone can completely collect dust while cleaning.
    If you use a vacuum cleaner then you are blowing dust around while you think you're sucking it all up, unless you have a super duper hepa micro high Merv filter. Carpets collect dust contrary to what you think when you vacuum.
    Have you cleaned the heat vents at the boots?
    Sep 2008
    24
    Quote Originally Posted by Bob Gabrilson View Post
    The fresh air exchanger gets it supply from a screened port thru
    the side of the house very close to the basement window.
    Sep 2008
    24
    Quote Originally Posted by bsum1 View Post
    I am not sure what a heat vent is?
    I use a bagless vacuum machine.after the dust,or debris is collected,there are 3 filters the air passes thru before leaving the machine.
    129
    Yes, I know that it brings outdoor air (and dust) into the house.
    My question is: where does the "fresh air" enter the house?
    Normally it's into the return duct (to be filtered), but not always.
    129
    Quote Originally Posted by deadshort View Post
    Thanks for the reminder.
    I dusted about 2 years ago and in looking around it may be time to do it again.
    That's very helpful, thank you so much.
    Sep 2008
    24
    fresh air enters the house thru the return duct located on the furnace .it is filtered before entering the house.the fresh air exchanger also has it own filter.
