    Default support for rounded bottom step
    What is the best way to create/build the rounded support that goes beneath the bottom step which is rounded on one side? Do you build the approx. 7" height out of 3/4 material and then cut the rounded shape? Thanks for the help
    1,130
    Default Re: support for rounded bottom step
    Bendable plywood over appropriately shaped wooden forms. The form should be load-bearing as the bendy-board isn't structural like regular plywood.
    S_M
    5,773
    Solid board cut kerfs in the last 7" so it can be bent.
    The shorter the curve the closer together the kerfs.
    thanks for the ideas. I'll see what I can manage.
