    Default Want to upgrade? Heating
    Actually , I dont know if it is an upgrade or just work.
    Currently I am on heating oil with heater vents on the bottom of the walls in each room. Last year I installed a pellet stove in the basement. I thought I would be able to transmit heat thru the un-insulated joist and it would heat the house. Well with or withiut pellets I ran the same amount of heating oil??????
    I heat my hot water with the same boiler and I never need to get heating oil in the summer months. Is there a way for me to convert a wood burning or coal burning furnace to my system?
    I do not want to pay $500.00 a month for heating oil on this small 1200 square foot unit??????????
    59
    Default Re: Want to upgrade? Heating
    first i'm no heating expert but I had great sucsess turing down high boiler temp to 155/160 degrees and had plenty of heat to be very comfortable. second my house is 1950's no in wall insulation and wall mount ac.
    JUST A THOUGHT BEST THING IS IT DOESN'T COST ANYTHING
    6,077
    You might try an old fashion way, Cut a gravity vent in the floor near the pellet stove and a return vent at the other end of the basement. Heat rises. You could even install a fan in the gravity vent.
