Results 1 to 7 of 7
Thread: GFCI Headache
    Default GFCI Headache
    I'm assisting a friend in adding a solarium using a partially existing room. The room formally housed a hot tub so rather than run new wiring, we decided to use the 50 amp breaker and line that was in place and we added a 6 breaker sub panel. By the way, for the record, I'm not a novice when it comes to residential wiring. Here's my problem. I want to run a string of recepticles off of one GFCI so I ran the #12 wire using a 20 amp breaker to the first box. Simple, right? Wrong. The recepticle is only about 2 feet from the sub-panel and when I put the GFCI in and turn on the power the reset on the GFCI immediately pops and won't reset. From the sub-panel to the recepticle, everything is right. Any ideas? I know the GFCI will trip with a neutral short so is it possible that another recepticle in the house has the common and "hot reversed backfeeding through the box. Help, I'm stumped.
    Default Re: GFCI Headache
    Quote Originally Posted by Rondud View Post
    we added a 6 breaker sub panel. .
    Is the neutral bus isolated from the ground in the sub panel?
    The neutral in a sub panel must be isolated from ground .... the neutral can only be bonded to ground in one location ... the main panel.
    just a thought.
    The subpanel is just like a service panel without the main breaker. It has two "hot wires off the 50 amp breaker at the main and one neutral bar.
    Does your sub panel also have a ground bus ?
    6,063
    It could just be a bad GCFI. Check the hot terminals, if you have 120 VAC, try changing the GCFI.
    As far as a seperate ground bus goes, I guess I'm not sure what would designate it as a seperate bus. It is set up just like a main breaker box with two feed lnes and a ground bar with a large lug for the ground from the main breaker. Its a Square D if that helps.
    Temporarily, I have put a 20 amp recepticle in and the voltage off each leg is right at 120 volts. I guess it is possible that I could have a bad GFCI but the reset stays in with the power off.
    6,063
    The GFCI has an electronic trip, so with the power off the trip is disabled.
