    Default NO insulation in 1965 bi-level. How far do we go?
    Our house is a bi-level, with brick on the bottom and siding on the top. We took the drywall off the two outside walls of one of the bedrooms downstairs and discovered NO insulation at all. Simply the concrete foundation up to half and then black scratchy paper that has the brick behind it. The top half as 2x4's along the black paper and the bottom half had two horizontal strips of wood that were used to attach the drywall to. I think we will be fine putting R-19 in between the 2x4's and an .5 to 1.0 inch insulating board along the concrete. That, along with a new energy efficient window, should be plenty for this 10 x 13 room. Rob wants to build into the room 1.5 inches for those two walls, putting thicker insulation in between the 2x4's and a 1.5 - 2.0 inch insulating board along the concrete. We will be insulating the rest of the house as well .. we'd like to know how far we should go.
    Default Re: NO insulation in 1965 bi-level. How far do we go?
    you can not let the insulation make contact with the concrete wall if it is open cell (bat) or it will wick the moisture, if your in a northern climate you may look into a vapor barrier before you put up the drywall.
    Oct 2008
    michigan
    32
    two pound polyurathane will create a vapor barrier and give you the best R-value per inch 7.
