    Apr 2008
    N. Eastern Wisconsin
    26
    Question Installing roof vent
    Hi all,
    I submitted this in the "Roofing" section, I want to post it here too.
    A couple years back I bought a vent to install on our garage roof as it gets quite hot in there during the summer. The vent has like a 10" hole in it. The garage is 24'x 24'. The roof has a center peak and slopes on all 4 sides.
    Which side do I want to put this on? Which way should the opening face ? How far down from the peak ? Does common wind direction matter ?
    Rich Kelly
    443
    Default Re: Installing roof vent
    Some of these sites deal with hip roof venting---you can use the vent you have & maybe incorporate into one of the systems below.
    Also Google "hip vent installation instructions", "hip roof ridge vents", "hip roof venting dilemna", "mid america components"
    http://www.trimline-products.com/div...0C2D6?Open&Pro
    http://en.allexperts.com/q/Roofing-1598/index_all.htm
    http://www.miltyr.se/roofing_ridge_master.html
    http://www.tapcoeurope.com/ridgevents.htm
    http://en.allexperts.com/q/Roofing-1...ge-Vents-1.htm
    http://en.allexperts.com/q/Roofing-1...idge-Vents.htm
    Apr 2008
    26
    jts, I didn't plan on the expense and time to install ridge vents. Altho, it might be an option. this is simply a galvanized square dome, or hood, with a 10" pipe rivited to the inside of it. Then there is a flat plate on the bottom to nail it down under the shingles.
    Rich Kelly
    443
    These vents are known as roof cans and are recommended for hip roofs---they are installed on any one of the sides near the middle top of the roof, 2 to 3' down from the ridge, but preferably the side with the prevailing winds---usually north---some venting at the lower side of the roof is needed to create an air flow for these vents to be effective.
    On the inside of the garage, drill a small hole between the exact center of two center rafters about 2' down from the ridge, & stick a nail thru so you can locate the hole on the exterior side.
    Check the condition of the shingles before you go on the roof, wear gym shoes---if the shingles are old & brittle walk very carefully---if the shingles are cupped & will break if you walk on them, use a ladder with attached 2 X 3's on the bottom that will rest between the cupped tabs---it is very difficult to get a color match between old & new shingles if the ones on there now are damaged.
    Leave the ridge shingles & top layer of shingles in place & remove a few shingles immediately around the nail hole---use a wide putty knife to loosen the sealed-down shingle flap/tabs & a small crow bar to creep under the shingles & loosen the roofing nails so you can remove the shingles without tearing or damage---if the shingles can be bent up without breaking, this job is a lot easier, both for removing the nails, & replacing them---discard the tar paper/building paper under the shingles.
    Cut a hole in the plywood/wood sheathing using the previously drilled hole as the center point to match the size of the new vent's hole---smear the bottom of the metal flange that will face the top of the roof with roofing cement & slip this flange of the vent under the upper layer of shingles & push it upwards--- hammer a few nails only in the top and side metal flange---do not put any nails in the bottom flange, which is to remain exposed over its bottom row of shingles---use wide head galvanized roofing nails.
    Not sure which way the open side of the vent should face---usually down, there is usually an arrow that indicates proper direction---there are often internal baffles that prevent snow from blowing in.
    It can be checked out if you can post the mfgr's name & model #.
    Cut & replace the removed shingles around the sides,top & bottom of the vent flanges as needed to neatly match the shingle rows & cover the vent flange, except on the bottom, carefully bending the upper row to slip the shingles underneath--sometimes a few inches has to be cut off the top of the shingle you are trying to slip under so it will go in & neatly match the row---if you can get some nails into the shingles without damaging them, do so.
    Use black roofing cement to seal the shingles & any exposed nail heads & nail holes to prevent leaks.
    1,131
    Scanned the thread and didn't see this mentioned -
    You'll also need intake/soffit vents.
    Apr 2008
    26
    JtS, thanks for the detailed explaination. Will make it easier going in. Good thing I asked, I never considered using roofing cement. Thought the shingles would suffice.
    ****hiller, the soffits are all vented. I also have a window going out to an enclosed screened patio that stays open through the summer.
    1,131
    Good deal. Then you're set for intake. Thumbs up.
