Results 1 to 10 of 10
    6
    Default Gas pipe line in kitchen
    The gas pipe line in the kitchen has a black wire coming from the basement as well. Is this a grounding wire and if so where does it attach to the stove? This is a hundred year old house so I am not sure if the Whirlpool 465 Super Capacity stove even needs to be attach to this wire. I just want to be sure it is safe to use the stove with only the gas line hooked up. Thanks.
    Default Re: Gas pipe line in kitchen
    There shouldn't be any electrical wires touching the gas line.
    Have you followed where the other end of this wire goes?
    6
    It looks like the other end of the wire is attached to one of the water pipe lines in the basement. I guess it's the grounding wire? (not sure) Thanks for responding. Is it supposed to be connected to anything or do I just let it be?
    Last edited by BJN; 08-12-2008 at 06:46 PM. Reason: Wanted to ask another question.
    I'm guessing your stove is gas?
    If so do you have a grounded receptacle close by for plugging in a cord for the accessories on the stove?
    I have no idea what this wire was used for but it sounds like an improper butch ground wire.
    6
    By "grounded receptacle" I guess you mean electrical outlet. Yes the outlets are grounded. And I see where the plug is grounded on the back of the stove itself (I am guessing the green wire b/c we just got an electric dryer).
    Maybe before the electric was all knob and tube (still have some)they used a different way to ground the house wiring(I don't know). So if the electric outlets are already
    grounded then I should not have a problem?
    Thanks for your help.
    Sounds like you're good to go.
    By the way ... you might want to remove that wire.
    Happy cooking
    The deep South
    459
    Happy cooking
    Canuk , you seem to be freaked out about that wire . Why ?
    Yep ... don't like the idea of any chance of energized gas lines.
    The deep South
    459
    I think I read somewhere that some jurisdictions require a metal gas line to be bonded . I was just curious .
    Really?!?!
    The gas company and inspectors around here would freak if they say any homes' electrical ground or cables in contact with the internal gas lines.
