    8
    Default Primer on textured walls
    What type of primer should i use on my newly textured walls in my basement. The texture was done with joint compound. I will be painting over the primer with a latex based pain afterward. Any brand suggestions would be greatly appreciated.
    Thank you
    Default Re: Primer on textured walls
    Whichever brand you decide on ensure that it's a primer/sealer for the new compound you put up.
    As a recommendation have the primer/sealer tinted to the same color as your paint .... this will help your finish coat look better.
    Hope this helps.
    8
    Thank you for the advise and quick response!
