Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    6,047
    Default Re: 3 way swiches with dimmer on both ends
    Quote Originally Posted by Gray Watson View Post
    Lutron maestro multi-location dimmer and companion uses standard 3-way wiring and can be dimmed from multiple locations.
    That's an IR controlled unit, so does it have to be line of sight?
  2. #12
    109
    No, not the IR system or remote system, I'm talking about the hard wired Lutron Maestro system. MA-1000 or MA600w is the master, then MA-R's are installed at the other control locations. No line of site. Uses the existing traveler wiring for a 3 or 4-way but in a different way. The companions are wired to the main controller blue screw to communicate, the companions and main controller are wired through black to **** to the lights. Simple no x10 no IR no transmitter/receiver issues, can always go back to old fashioned 3 or 4way switches.
    I installed these in my family room, I couldn't find the 1000w controller at the big box had to get from lighting supply. Installed in a multi-gang so had to derate 200w for removing fins so couldn't use the 600w controller. They work great and don't cause any issues with the other communications and entertainment systems I have going on in that area.
    Sent you a PM with a file Jack.
  3. #13
    6,047
    Thanks for the info Gray, I see they also have RF controlled devices as well.
