    59
    Default burnham oil boiler with hole
    hello i have a burnham oil boiler with a hole burned thru the burn chamber across from nozzle how do you repair that
    Default Re: burnham oil boiler with hole
    It depends on whether this is a dry base or wet base boiler. If it's wet base, the front plate that the burner mounts to is removed and the chamber or target, whichever it has, is easily replaced.
    If's dry base, not too easy. The boiler section has to be removed from the base, the chamber swapped out and the boiler section re-installed.
